Triton Maytronics robot can't work with FC level over 4ppm?
ste
Active member
Apr 25, 2019
37
costarica
Manual of instruction of the triton say don't use it with FC over 4ppm, but with CYA at 40 i keep the FC level at 7 ppm , minimum 5ppm ....any advice?
ste
Active member
Apr 25, 2019
37
costarica
Ok so i also can use it during a SLAM ?
That will help a lot if i can use the robot with a FC of 16 with CYA 40 during the sSLAM process at night time ,becouse i have a solar pump and at night doesn'r work so i can put the robot inside instead ? Well if you had it in your pool with FC at 20 , i think i'm fine
So why the Manual say :don't use it with FC above 4ppm?
tim5055
10,923
Franklin, NC
They don’t take the effects of the CYA into account. But, I don’t think I’d be using it at SLAM levels. FC 16 with a CYA of 40 is a lot more harsh environment than FC 20 with a CYA of 200+. I was nowhere near SLAM level.
