TriStar diffuser is this vent hole normal?
willygee
79
central fla
If not can it be epoxied?
willygee
79
central fla
Wear ring split. Can i run without the ring until parts arrive. Pump was working fine..plenty of pressure and quiet.
JamesW
24,810
It should work ok without the ring until you can get a new one.
I would replace the diffuser.
willygee
79
central fla
Pump works fine without impeller ring but has slight gurgling sound...new diffuser and impeller ring on order.
Reactions: JamesW
