Total system failure from stressed valve actuator?
mknauss
23,451
Laughlin, NV
All you need is a basic Voltmeter. It might be digital and will most likely need a battery. Should be under $10 unless HF is having a promotion.
ajw22
12,890
Northern NJ
Reactions: setsailsoon
Wilco500
22
Tucson
I replaced the fuse on the power center which I found was blown, but each time i turned on the power, it lit up briefly then blew the fuse. ( so much for that $6). So i think my circuit board is bad.
ajw22
12,890
Northern NJ
Show us where the fuse in the your power center is. What size is the fuse?
Jimrahbe
15,778
Bedford, TX
Wil,
When you replaced the fuse, were the valve actuators connected to the main board or not??? I suspect that if you disconnect the actuator connectors, that the fuse will not blow.. If that is true, then you then will just have to figure out which actuator is bad.. :mrgreen:
Wilco500
22
Tucson
Its gotta be the one that started the problem, i got a guy coming out monday, but at least i have it narrowed down and the hit should be less. Thanks for you alls help, i do appreciate it.
Wilco500
22
Tucson
I unplugged the suspect VA, replaced the fuse, fired it up, and everything is back on. Looks like I need to replace the VA. Thanks again for your guys’ assistance. 👍
