I recently filled a pool and have been trying all week to balance the chemistry. I make my own daily tests with a Taylor FAS-DPD kit and I confirm my test results by taking water samples to Leslie's. I have managed to get all the chemistry within recommended range except for pH and Total Alkalinity.
If TA is too high, I add the amount of acid recommended by Leslie's computer printout. This brings the TA within range but lowers the pH too much. So the next day's computer printout tells me to add soda ash. The soda ash brings the pH within range but also raises the TA too much. The next day's computer printout tells me to add acid. In fact, it tells me to add the same amount of acid I had added two days before. Clearly this is not working.
Currently pH = 7.4 and TA = 130. If I add a small amount of acid, I may be able to get the pH down to 7.2 or 7.3 and TA to 120, which is right at the upper limit. But given the fact that these two move in lock step, it seems that there is no way I'll be able to adjust both pH and TA to their ideal values (say 7.5 and 100). Or is there?
Is this a known problem? What's the solution?
