Too much Salt?
Carhub
5
Savannah, GA
I have an Aqua Logic system. It is about 12 years old. I got a salt too low and chlorinator off message. I added salt. It did not go away so I added more salt. It still did not go away. I checked with local pool people and online and all indications was that the T-15 cell had finished it life. 12 years was a pretty good run. I ordered a replacement cell, not the original manufacturers replacement but the more economical brand. Now it is reading salt level too high and chlorinator off message. My online search for answers continued. I came across TFP and started reading some old posts with the same problem. They suggested re-soldering a burned spot on the back of the mother board. I did. I did it three times still the same readings. The actual salt level in the pool is about 2600 ppm (strip tested). Am I supposed to do something else to that spot on the back of the mother board other than heat it up and add some solder to it? What can I do now? I hope some out there has a solution. Thank you from Savannah, GA. Carhub
Welcome to TFP.
What are your diagnostic readings?
You really need to get the K-1766 Taylor Salt Test for accurate salt measurements.
Are you getting HIGH SALT or LOW SALT error now?
That's for AquaRite. They have Aqualogic, which is the precursor to ProLogic.
Go to diagnostics and see what the readings are. Then, press + to reverse polarity and see what the new readings are.
The high salt error can be a problem with the K1 relay connection on the board.
You will find a summary of the problem at..
and a much longer thread to wade through at
If the operating voltage is high (like 40 volts), that's usually a solder issue.
If the operating voltage is in the 24 to 28 volt range, and the amps are over 8.0, that's usually from the salinity being too high.
I got a K-1766 Taylor Salt test Kit. You all were right. With the new kit the salt read nearly 6000 ppm. I drained more water and refilled with fresh water. The salt level is down to the low 4000 ppm but the amps are still above 8 amps. Do I need to drain more water and refill with fresh water again? Will that reduce the amps?
