Depends on water temperature. If the temperature is high, then it will be a problem. If the temperature is low, probably not a problem. It goes by amps, if the amps are below 8.0, you’re good.
What are the readings in diagnostics for salinity, amps and water temperature?
If you heat to over about 90 F, you might hit 8 amps. Allow the salinity to drift down over time so that as the water gets warm, you won’t have an issue.
Also note that salt tests are not super accurate. Your readings are close enough to each other to be in agreement within the accuracy of the tests.
