I just backwashed my DE filter by turning off pump, then switching the slide valve to backwash, run for 3 minutes, stop pump, switch valve to normal operation for about 30 s, then pump off, slide valve back to backwash, turn on pump for about a minute, then this process once more with reduced times. I looked on the DE filter and identified that I needed 1.3 Kg of DE, added using a scale that measures quite well. Poured DE into skimmer basket. Now I have what appears to be DE on the bottom of the pool. I brushed the entire pool a few times with the pump on high and the material just seems to settle back down. Also running the robot cleaner for a few times and it also has cloudy material in it. Is this indicative of too much DE? best solution? thank you
