Too much CC
Rescue30
73
New Jersey
Hi
Hope everyone safe during these crazy times. Need a little help. Opened the pool two weeks ago, looked like a swamp. Vacuumed to waste, Dolohin M5 for two days straight constantly emptying it every hour. Water got clear and no junk in the pool. Added CYA and now pool is now sparkling clean but CC are too high....
FC 8
CC 2.5
PH 7.5
Alk 100
CYA 60
I used five gallons of bleach one night last week to SLAM it
setsailsoon
3,841
Stuart/FL
CircuPool RJ-30 Plus
30,
Did you pass all the criteria for a SLAM? Either way, looks like you need to SLAM again. Make sure you continue the complete procedure until all criteria are met.
Chris
Reactions: Mdragger88
Rescue30
73
New Jersey
I'm going to check the numbers , SLAM again this evening and check again in the morning. Just trimming to figure out how CC stayed at 2.5 the whole time. Yes if course I'm using the TF-100 test kit....
setsailsoon
3,841
Stuart/FL
30,
I've seen a lot of posts where CC remains at a given level. Not sure why but this is the way I think of it. When you SLAM it's a continuous process so organics are continually oxidized, and partially oxidized. Eventually, everything does get completely oxidized. So it's very common that your CC stays at a given level. Then when there's no more totally "untouched" organics the chlorine works only on the partially oxidized material and your CC begins to drop. I'm sure this is a little over-simplified but it does make sense.
Once you get this all cleaned up you'll usually get to 0 cc but later on if you get an unusually high load or let FC levels slip to a low level it's not unusual to see it jump up to .5 for a few days in a row. Eventually it will go down to 0 again.
I hope this helps.
Chris
Rescue30
73
New Jersey
Hi again
Last evening I did the SLAM , pool math told me I needed 11 jugs of Bleach CYA is 60.
I forgot to turn off my SWG (dummy me)
This morning pool is sparkling. FC is 28 !! CC is 1, down from 2... I brushed all the walls and floor after I got the bleach in and saw a drop of cloudiness come off the wall , which I guess was algae ?? Pool looks great but at what point is swimming ok.....
mknauss
36,021
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Follow the SLAM Process until you pass all three criteria.
You can safely swim in a pool as long as the FC is above the minimum and at or below SLAM level based on your CYA. You must also be able to see the bottom of the pool in the deep end of the pool.
Rescue30
73
New Jersey
Thanks. So according to the SLAM chart it would be 24. I think the bleach +SWG took it over the top , which only got rid of 1CC.
I have to add some a couple of inches of water now and will retest afterwards
Rescue30
73
New Jersey
Ok
Just tested again : FC dropped to 20, CC was a drop under 1 but higher than 0.5 meaning one drop off the 0871 made it almost clear . Second dropped make it perfectly clear.. I added another 2 gallons to bring up the FC level to SLAM again
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,517
That CC test means your CC is .5 ppm and you pass. All drops based tests are completed when the last drop you add results in NO FURTHER CHANGE. Sounds like your second drop did just that so your CC's are .5 ppm which is the same as zero for TFP purposes.
Reactions: setsailsoon
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,517
If it's just for the weekend I would turn it off. With a CYA of 60, you should have adequate FC to last 3 days or so.
