- Nov 10, 2022
- 10
- Plaster
- CircuPool RJ-30 Plus
Had pool resurfaced with a pebble finish on 11/1/2022 and builder did initial startup. I took over maint and chem balancing from the PB on 11/6/2022. Per TFP forum recommendations I followed NPC startup guidance processes. On 11/27/2022 started using a Taylor K2006-C test kit and tested CH to be at 330ppm. Kept it all balanced and chlorinated with liquid chlorine till I converted back to my SWG system on 12/1/2022. Since SWG conversion on 12/1/2022 I have kept the water perfectly balanced and within the Pool Calculator recommended CSI ranges.
Today I decided to randomly test my CH since I had not done this for the past three months. I was shocked to see my CH is now at 550ppm. I verified this by retesting different pool water samples three times. I also verified my city tap water is at 100ppm CH.
I'm totally baffled as to how my pool water could climb from 330 to 550 ppm CH over three months. I have not been adding any chemicals other than diamond brand pool salt from lowes to get my salt level to 3600pppm for the SWG startup, two bottles of Jack's magic magenta during initial startup, four pounds of baking soda during startup to raise my TA and since then lots of muriatic acid to control my constant creeping pH that I attribute to the new refinish and SWG system operation. My current levels today are: FC 5, CC 0, CYA 40, TA 70, pH 7.9, CH 550, CSI 0.22.
Can anyone help me out on why my CH may of gone so high so fast? Also what I may look to do to prevent this from happening again if I drain my water down and do a partial refill to get this CH back down to a level of around 300-ish? Thanks.
