TIps for a 4Wheeler "Pool Cleaner?"
Summersgal
Active member
Mar 13, 2008
35
Muskogee, OKLAHOMA
Well the "Pool Cleaner" came yesterday. Put it in the pool this morning and have fought the stupid thing all day! What a disappointment! The thing will not climb the walls as promised nor will it even go to the shallow end of the water to clean the pool. Took the weights off then even back on..just not what I expected it to be.
If anyone has any tips that they would like to share I would be very happy to try them. IF it doesn't get better I will be seeing if this thing is returnable!
Thanks in advance
salinda
130
Los Gatos, CA
You might have to reduce suction on your skimmer/main drain some. I have a vacuum gauge on my pump that I use to dial this in a little better. You will have to adjust this until the wheel rotations are what is recommended. Mine climbs very well, although it is a 2-wheel model. Why did you go with the 4-wheel model? I was told if your line is towards the middle the 2X will do fine. I have a much larger pool than yours and I have the 2X
