Timer model
Flbeachluvr
417
Port Orange, FL
C96AB46B-48C4-4128-BED9-0BD2462F7081.jpegI have an Intermatic timer that’s no longer turning on the pool pump. I can manually turn it on and then the timer will turn it off. The trippers are fine and I can hear it running. Clock works. I’ve seen that there’s a part behind the clock that can wear down so the tripper won’t turn it on. Looks like I’ll have to replace the timer however I can’t find a part number other than what shows in the whole control box. Help.
ajw22
29,746
Northern NJ
Pentair Intellichlor IC-60
Post pics of the timer mechanism.
Is your pump 120V or 240V?
You use a T101 mechanism for a 120V and it has a 120V clock motor.
Or you use a T104 mechanism for a 240V and it has a 240V clock motor.
ajw22
29,746
Northern NJ
I need to see the timer wiring that is under the OFF - ON black guard. Turn off the pump CB before removing the black plastic guard.
