Time for a remodel (facelift). Staples vs Polyurethane for crack repairs
roblutts
16
Plano, TX
Hi all and thank you for your time. Purchased current house in June of this year. Pool build is estimated to be around 2000 based on some info and style that I have. 2012 there were some major cracks that were repaired and you can see the scars from that. During the buy, they hired that company to do a leak test to prove that everything was good and I have that receipt. There is some separation in the plaster in one area that is at least 1/8" open where you can see it's failing. And now I'm losing water and have done the bucket test etc., to the tune of at least an inch a day regardless of pump on/off. I'm pretty sure it's never been replastered, so it's done its job I feel. Got a couple of quotes and one company proposes staples and the other tells me that they believe in polyurethane and that it is better than staples. Pool is about 13k gallons.
Using standard white replaster, replacing waterline tiles, return jets, mastic for the deck, chemical start-up, etc. One is around $10k (staples)and the other $8750 (polyurethane).
Thoughts/opinions?
Thanks in advance!
mikes112
72
New Jersey
Repair what?
Repair the bond beam. Which mix should I used? I used Quickcretes highstrength mix to repair part of the foundation of my house and there were a lot of small voids from the rocks in the mix. I like Rapidsets mortar mix but its only sand and portland cement. Im going to be fixing it this week as I already have the forms and rebar. A preset mix is ok, but not so chunky with big gravel. What do the pros reccomend?
ajw22
17,884
Northern NJ
We will ask @bdavis466
  • Love
Reactions: mikes112
