- Aug 20, 2021
- 27
- Plaster
- Jandy Aquapure 1400
HELP...Hi everyone. I need opinions. Stated tile on Tuesday. Came home to some issues. Loose tiles (ok, not a big deal easy fix). Then my waterfall columns waterline. They stopped tile at edge of column which would have given it a giant grout line that he was going to bullnose around. It was going to look awful. Talked to PM told him we wanted grout line on sides of column, the corners needed to be the clean side of tile (not cut) and face without a bullnose grout line. Then the columns were 1/2 inch off from each other. OK. PM stepped in told contractor who copped a major attitude with us.
Day 2- on one column he got the gist and fixed the face but now we had crappy uneven tile cuts. PM - Not bad and won't see when grounted..uh..yes we will. They then repeated Day 1 on only one side of the column (WTH). When they put my veneer on the column they did the same thing inconsistently. They tiled great then decided to have a side tile showing in the front. So hard to explain. Please see pics. PM agreed they ripped it out. Can you look at pics and let me know if I am being unreasonable or can you show me pics of your columns? PM said they will fix everything. I don't have his confidence. Bad cuts cuts to me are crazy. We have had tons of tile work. Never this sloppy. This is day 3, still same issues. Not to mention a cracked veneer right down the middle was installed. I don't have a pic. But it too needs to be changed out. TIA.
