Tile help!!!!
houston_tink
75
Belton/TX
Gunite is complete and we have a transparent/iridescent MasterTile going on infinity edge, spa overflow, and water line. The tile looks splotchy (has dark areas) for some reason. The builder says it is moisture behind the tile that hasn't dried. The problem is it rained today and it got worse so doesn't that mean when there is water in the pool it's always going to look bad? Surely if moisture can get behind there that can't be good? It is over the entire perimeter of the pool.
Nursenini
2,122
Bixby, Ok
I would be asking exactly WHAT they used behind the tile. From my own bad personal experience, having your glass tile PROPERLY installed with a moisture barrier in place will keep you from having this issue and efflorescence down the road.
danpik
1,686
western NY
It looks like moisture back there to me too. It is there because I don't think he got the tiles completely embedded into the thinset and there are air voids back there holding the moisture.
houston_tink
75
Belton/TX
It looks splotchy all the time but intensifies when wet. But the splotchy areas do not spread at all. Here is a pic of the spa where the sheets of tile are joined and you can see the dark areas
kevreh
In The Industry
Jun 2, 2007
412
Annandale, VA
How long has the tile been up? Its possible that some areas of thinset haven't fully cured yet. Glass doesn't breath so thinset takes longer to set up. IIRC recomendations are to give it a few days, up to a week to fully cure (setup). Ditto with the mortar or concrete behind the tile, how long has it been drying for? The tell is the dark areas where the sheets meet. That just looks like different areas of thinset drying at different rates.
The first pic looks like there's moisture behind the tile. Tile isn't fully set in the thinset so moisture is in the gap behind the tile or, again, the thinset hasn't fully cured. To have moisture in a void behind the tile means they didn't install it (glass tile) right. Your supposed to spread thinset with a notched trowel, then spread it flat, then embed the tiles. It is a known problem when the glass tile is only embedded in knothed thinset and the pattern show right through the tile.
If you reply and say its only been up a couple days I say wait. If its been a solid week then thats a different issue.
houston_tink
75
Belton/TX
Gunite has been in 3 weeks-sat for 5 days and then they started tile. So tile has been on almost 2 weeeks
Thread starter Other Threads of Interest Forum Replies Date
UrbanCoyote Everything Else 5
K Under Construction 12
Teen124 Everything Else 1
