Nearly complete with a 75x12' lap pool. Shotcrete + plaster/quartz. Water in it for almost 3 weeks.
As it turns out, the pool is just under 73' long. I didn't have a tape measure to measure it at the time and we had some other issues during excavation (we had to over-ex for clay) that set things back and distracted a bit. I'm honestly not super stressed about the length, as I'm not running competition or anything and the length is still very effective for swimming laps.
The coping concrete around the pool is already developing cracks. About every 5' around the perimeter coping there's a crack that's 1mm wide.
The railing/handles that were just installed today didn't have the anchors put in right. They put the anchor in, attached the railing then filled around the anchor with concrete (installed after coping was poured). So there's not even any access to the anchor anymore. And only the back bar of each railing (it's a 2 post rail) actually had an anchor.
But my reading says the anchors should have been set in concrete that dried first before the railing was installed. Or is it normal practice to bury the anchor in concrete? In any case it wobbles a bit after 36 hours of setting and no one has put any weight on it yet. I just worry it will be an issue in the future.
The heat pump was installed about 14" from the house wall not 24" as the manual says. And the filter is even closer, so it also reduced air flow on that side as well.
The pool has 2 skimmers, which either isn't enough or the pump isn't that great as they don't seem that effective at getting flow going. The vacuum (poolvernugen) seems pretty slow too (with skimmer turned off and drains almost all the way closed). Those things make me wonder if the pump is the wrong size. Century 1.5hp pump, hayward c4030 filter, hayward heatpro 140btu heat pump, hayward omni logic controller.
In any case, how would you address these issues in my case? Should be asking him to fix all the cracks? It's the railing a big issue? There's not much I can do about the length at this point, and I don't want any one to take a bath here, as the guy has to make a living too. But am I being too understanding?
The builder seems like a good guy. I'm wondering how much it's worth a fight over this stuff or if it's par for the course of dealing with occasional issues and just moving on.
60k pool price incl auto cover. 10k extra for the over-ex from neighbor trusted contractor that was quite extensive with gravel, road base, 175' of drain, etc
