Third Sand filter replacement in 6 years
ayersmb
3
Edenton, NC
I have a Hayward S220T sand filter that has a leak on one side at the seam. Same failure location as the 2 previous tanks. Something must be wrong so I am coming to the experts for help.
Here are my specs
In ground fiberglass pool - size approx 25x11x4 - see photo. Not sure of volume
Hayward super pump - 1.5 HPc48l2n134b1
Sand Filter Hayward S220T
What would be causing the repeated failure? Is there a better replacement?
What is the filter pressure when running?
I wonder if Heyward is having any issues with their tank manufacturing? Have you called them and asked why you are on your third tank with the same issue?
