Reference the Pool School - Chlorine / CYA Chart
You stated you added enough stabilizer get CYA to 50. Once the CYA is added, just consider it in there and dose accordingly. You need to add bleach to dose FC to a target of 6-8 -- and never let it fall below 4. Remember, you're pool is a NON - SWG pool until AFTER your salt level is correct and the SWG is functioning correctly.
You also need to keep the pH in check - letting it get above 7.8 is bad.
Please provide a current
FC
CC
pH
TA
It's all about the test results... stay on top if it or you will be working double time to correct it.
And just to keep everyone happy, how about pics of all your hard work.... pool, pool equipment -- and a pic of the brick just for Dirk!!
Thank you Gene. I will make sure to keep the levels good, at least as much as I can with my old possibly inaccurate kit. Today's my busiest day of the week so I'll get pics ASAP, but testing first!
