My wife is compaining about the noise level of the 1.5 HP single speed pump that came with our AGP. After reading about methods of noise abatement, it looks to me like the best solution is to get a VS pump.
I first became interested in a V-Green 1.65 HP thinking I could just swap it with my current motor. After looking closer I see that is doesn't have a mount, so I assume it connects to a basket assembly that has a mount build into it.
I looked at a couple brands, but being a new and satisfied owner of a CircuPool SWG I am currently looking at their CircuPool SmartFlo® Variable Speed Pool Pump - 1.5 THP
It too does not have the mount on the motor, just a support extending back under the motor from the main mount under the basket.
What I would like to know is if the bolt hole pattern on said mount would be the same as the holes my current motor mounts in. I talked to tech support and they just weren't sure. You can see the mount attached to my motor in the attached photo and also the fact that it is mounted into a stand made for it and my sand filter. The holes in this mount look like they are the same as fan motors I have worked with in the past so I am thinking maybe they are standardized. (The manual for the SmartFlo says you should have 5x the pipe diameter in a straight line before entry into the pump - I will deal with that as necessary - just added this tidbit of info in case anyone notices).
Thanks for any input.
