OK,
HP 900 Thermal Flow Pentair.
I have an Intelli Touch controller and it has a relay dry contact output that is wired to the heat pump to turn it on.
Worked past 3 seasons just fine.
recently my Run cap went bad and when I got it working, I was having to manually operate the heat pump at the heat pump control pad.
Using the Intelli Touch to set up the temperature and operate it is not working.
The Remote mode is turned on in the Thermal Flow control panel.
RELAY REMOTE
REMOTE IS ON
I can see the resistance across the relay drop down to 0 when the Intelli Touch turns on the heater, but the Control panel does not recognize it.
I can measure it at the INtellitouch as well as right at the spade lugs of the Thermal Flow board.
Looking like the control panel board is faulty
Don't know if there is something I"m missing here.
RELAY REMOTE
REMOTE IS ON
