Update 1: Thanks for the reply. I'll revert within 24 hours with all the info asked. I figured it might be necessary. (I have corrected the grammatical mistakes, I was typing via my phone's keyboard)
2: This is a 10000sqft commercial pool, 4ft depth. That is a LOT of water to change each time. It was done just a month ago
2.1: The filteration plant is an Astral Pool Volcano High Rate Sand filter (Filter Diameter 1200mm) X 3 nos.
3: Please also look at it in the angle of sabotage, is it possible?
Hi guys
I was searching the internet for answers when I stumbled upon this gem of a forum.
I have had this pool for nearly 8 years and it has been flawlessly maintained. Recently the water mysteriously turned green. We tried everything but to no result.
Eventually we drained the water, cleaned the tiles and refilled water.
This was 1 month ago, but now the water has again mysteriously turned green. Whenever chlorine is added it turns green...
The only thing I can see different is that the sand used as filter was changed before this issue began...
What do you think the problem is?
Note: the blue gradient in the bottom right of the image are the dark blue pool tiles
This is the water as of right now
Below are the reports from last month before the entire pool was emptied and cleaned. The well water was being used to refill. Its a natural open well that used to have close to drinking water once upon a time.
I have also attached the swimming pool water report for you to gauge the effect the filtration plant has had on the water.
Hi guys
