The Pool is almost done... Roseville, Ca.
RobertFlagg
88
Roseville, Ca
Ok, Next step is the water line tile. I have no idea what tile to select. The problem is none of the typical showrooms are open due to the COVID-19 thing. NPT will let me borrow some samples to put next to the pool for comparison, but I don’t even know where to start. Any and all recommendations are welcomed. Pictures are great too....
Things I do know
-Pool color with be a dark blue
-QuartzScapes, Barbados Blue
-Pool coping, cantilever matched to the pool deck.
-Standard concrete grey with salt finish
I do like NPT Lightwaves, Aquamarine 1x1 for the pool steps.
Thanks
kimkats
48,365
Tallahassee, FL
YES!! AND use it for your water line tile!!! OH the BLING when there is water in the pool and the sun is shining!!! You can even get extra to use to put on top of a table, bench, around flower pots, etc................bling it out!
Kim:kim:
RobertFlagg
88
Roseville, Ca
I like the bling of those tiles, in moderation. I'm worried about all the cleaning of the grout lines. They have these new pool tiles 6x12. I was intrigued because of the lack of grout lines, easier to clean? The pool is a rectangle, so it would be easier to install the larger tiles. Has anyone installed these type of tiles?
kimkats
48,365
Tallahassee, FL
Now that could be FUN to work with!!! Think about this.............put one row of the BLING tile between every 2 or 3 large tiles! Talk about knocking it out of the block!!!
Now if you do go with this bigger tile the placement is going to oh so important!! I would do some major measuring to make sure you start in the middle with full pieces with any smaller pieces being EVENLY on the ends! Do you understand what I mean?
Kim:kim:
RobertFlagg
88
Roseville, Ca
Totally, thanks for the suggestion. I do like the bling in between the long tiles. I've done a lot of tile jobs but I'm not sure if I want to do this one. I've never done a pool tile job.
kimkats
48,365
Tallahassee, FL
Tile is tile I thought??? Me? there is NO way I would even try it as I like having some one to blame if it gets messed up LOL
RobertFlagg
88
Roseville, Ca
Day 1 of 2 on the Gunite. The pool is starting to take its real shape. Sorry about the blurry photos. Backyard webcam. Will upload some when I get home
kimkats
48,365
Tallahassee, FL
SWEET!!!!
Guess what time it is...............time for YOUR set of links!!!
Plaster links:
Ten Guidelines for Quality Pool Plaster Best one of all
All Plaster Finishes Should Last 20 Years
Not All Color Pigments are Good for Pools How to pick a good color for plaster.
A Plastering 'Watch List' | Professional Watershaping | Watershapes
Trouble Free Pool
Trouble Free Pool
Pool care links:
Print these out:
Bookmark these:
Trouble Free Pool
Now is also a good time to ask what test kit your PB will be providing so we can fill in any holes.
Kim:kim:
Reactions: RobertFlagg
RobertFlagg
88
Roseville, Ca
*Update*
The gunite is done and the tile was just installed. the tile is straight and it looks great. They floated out the pool to make everything straight and level. We went with NPT Slate, Stone Look Tiles, 6"x12" Ash (SLT-ASH6x12) The only question I have now is the finished look at one of the returns. I'm sure the idea was to fill the gap with plaster but i think it would look alot better if they carried the tile down in line with the rest of them. Thoughts?
kimkats
48,365
Tallahassee, FL
The brown board will be removed. The only place I see something I would "fix" is right under the skimmer box. I would have them cut a small strip of tile so it matches the bottom of the other tiles. It is going to take a sure hand with the tape measure and saw but if they have any skills they can do it! The returns I would leave like they are.
mguzzy
Yeah the brown board is temporary to keep the tiles level. I be. since they tiled the portal to the skimmer I bet they tile that small section their to make it even with the other tile. You will never notice that one return put being at a different depth. It will be underwater.
RobertFlagg
88
Roseville, Ca
I also just finished installing the 4 GloBright LEDs in the Color VIsion Bubblers and 2 GloBrights in the pool walls. Wired them all the way to the junction boxes. I took some time to think about how to accomplish that, but I think it turned out nice. Looks clean as can be. I also ran the pull string in the 140' run to the pool pad. I will be running a total of 4 12awg wires from the junction box to the transformers. I have the 100 watts for the two pool lights and the 300 watts on for the 4 Led's in the bubblers. Anything else I'm missing? I will be running them independent of each other on two relays in the IntelCenter. IMG_1226.jpgIMG_1227.jpgIMG_1228.jpgIMG_1229.jpg
Another project was to run the 50' of Stegmeier - Frontier Deck Drains along the old patio edge. The future concrete patio will tie into the channel drain and help with the not perfectly matched colors of new concrete and old concrete.
kimkats
48,365
Tallahassee, FL
Tap Water Test with TF-100
FC - 0.5
CC - 0.5
pH- 8.2
TA- 70
CH - 75
You water is as different as it can be from the other one we just saw! She is going to go through a lot of muriatic acid due to her high TA. You will go through it just because of the new plaster.
You will need to add some CH to your water so add that to the list. Look in my siggy for recommend chemicals.
So here is your shopping list:
-2 2cup PLASTIC measuring cups-1 is for the muriatic acid and the other is for all other chemicals
-white plate to hold up behind the pH tube to help color match
-new toothbrush so the pool can have your old one (great for cleaning around the return and skimmer
-Something and some where to store the muriatic acid. It can NOT be stored inside by metal or by the chlorine-they do not play well together. The M.A. fumes will cause metal to rust. Most people get a plastic bucket BUT make sure the lid can be vented. It can be store outside as it does not care about sun or heat. If you have kids you will want it where they can get to it.
-Find YOUR best source for LIQUID chlorine-some pool stores sell it but you have to put a deposit down on their jugs (it is worth it)
-muriatic acid-the 31% kind from Lowes or Home Depot. It will be outside by the pool stuff in a box with 2 jugs in it.
-PLASTIC drink cups and plate to have dinner by the pool!!!
Kim:kim:
RobertFlagg
88
Roseville, Ca
Update, some of the flat work has started and pool pad setup is going.
Reactions: mguzzy
