First off a big thank you to TF Pools and those of you who have answered my previous questions. As a pool newbie I was a bit hesitant to take on the DIY installation and maintenance of a pool, but after a few bumps and mistakes I now have a pool that is perfectly clear, balanced, and being enjoyed by the family.
Now a couple of questions.
1) When hooking up the vacuum it's almost most impossible not to suck in a little air for a second or two. From what I can tell, this air just gets pushed right through and back out the returns, but I just wondered if I should be worried about this at all?
2) My pump (Hayward Maxflow VS) has the option of running a prime "cycle" each time the pump is turned on. The pump is below the water level so it says full without any priming. Is there any advantage to having the prime cycle run, or should I just turn it off? The advantage of turning it off is that when it runs, the suction on the skimmer is strong enough that if the water level has dropped much below halfway on the skimmer, it will pull air in during the priming cycle, so turning if off would mean I would have a little more room to let the water level vary during dry hot spells.
