Someone drove their car into a pole up the road from my house today. When I got home this evening it was obvious I'd lost power for some time and the pool equipment is dead. Checked the sub panel. Main, light and receptacle breakers were on. Breaker for the SWG was on. Siemens GFCI breaker for the pump was tripped. Cut everything off and reset the breaker. Turned everything back on and it fired up perfectly.
The GFCI breaker functioned exactly as it should and shut down power to the pump. The current sensing relay also did it's job and there was no power to the SWG even though that breaker had not tripped. The flow switch should have kept the SWG from generating but they're far from foolproof.
Nice to come home to no equipment failures and know that all the wiring works exactly as intended.
