TF-100 test kit has arrived!
dangelini
Active member
Aug 16, 2019
26
East Sacramento Area, CA
Socks are out. Will measure resulting CYA in the morning.
Skimmer water was full of gross floating bubble scum layer; I think the CL blast is starting to work. RIP algae.
I swear those socks were clean when I put them in. :p
dangelini
Active member
Aug 16, 2019
26
So far the SLAM is going well.
Brushed this morning. Measured CYA: 30, FC:15 CC: 2
Three hours later, measured CYA: 30, FC: 11, CC: 0.5. So I used pool math to figure out how much CL to add to get FC back to 12 . (SLAMming at CYA-30/FC-12).
Brushed again - no more green visible while brushing. Water looks nice.
Will keep it going.
wireform
In The Industry
Aug 15, 2017
2,507
Spring Valley, NY
It's important to stay on top of your slam. Keep bringing it back to slam level as often as possible. The more you maintain slam level the faster the slam works. Very important is for you to maintain the Cya/chlorine relationship.
dangelini
Active member
Aug 16, 2019
26
Cool, will do.
One thing that perplexes me is ... once I add CL to bring it back to the appropriate level, how long to wait till retest? I suspect i should wait for the CL I just added to disperse evenly across and throughout the pool. Pump is running constantly during this, but not at full power, at medium power.
I'm currently guessing (which I suspect is bad) that it takes about 3 hours for this to evenly spread throughout the pools.
mknauss
41,632
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Within thirty minutes most liquid chemical additions should be able to be tested.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,518
The length of time between dosages gets a little longer as the end of the SLAM gets closer and closer. It's an arbitrary number but I think 3-4 times daily is reasonable when you start the SLAM and then twice daily is adequate as you approach the end.
Judge it by your consumption rate. You will see the FC loss start to wane as you burn the organics in your pool. Losing 4-5 ppm in between dosages is probably about right.
