Testing city water with pool test kit...
PieterS
177
Minneapolis, MN
OK - so not quite on topic - but having recently installed a whole-house carbon filter, and now wondering if my 10-year-old water softener resin might need replacing - is the TF100 or K2006C test kit useful in testing your household tap water?
Specifically:
1) is the calcium hardness test equivalent/useful for testing the hardness of city water? Does it correlate to 'grains' of hardness?
2) Is the CL test sensitive enough to test the amt of chlorine typically added to city water for sanitization? And therefore I could measure it before/after the water filter.
Thanks!
mknauss
51,246
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Yes and yes.
GPG = ppm/17.118
Be sure to do the CC portion of the FAS-DPD, some water systems use chloramines.
Reactions: wireform
PieterS
177
Minneapolis, MN
Gave this a shot - seemed to work. Trying to figure out of it's close to time to replace my water softener resin bed. Just before regenerating, the calcium hardness was around 160 ppm (hard to tell the red to blue/purple transition!) so around 9 gpg - the incoming water tested closer to 200 ppm (almost 12 gpg). AFTER regenerating - the calcium hardness hardly registered.
The chlorine test (to check on the whole house carbon filter) was a bit confusing at first. Taken from the outside spigot (hard, non-filtered water) I still registered NO chlorine. Thinking maybe I didn't flush enough water out first, I did recall I have a drain spigot inside that is before the filter/softener - tested that, and I registered between 0.4 and 0.6 PPM. Still maybe a bit less than what I'd expect in city water? But I don't know what I should expect... The AFTER filter water didn't register ANY chlorine (didn't turn any shade of pink after adding powder).
mknauss
51,246
Laughlin, NV
Fiberglass
Sounds about right. Metals in the water can interfere with the CH test. There is a protocol for that in the Extended Test directions in Pool School.
That amount of FC in tap water sounds about right. Can be higher (EPA allows up to 4 ppm FC) but typically it has fallen by the time it gets to you.
Oly
2,765
Fresno, CA
I only recently bought one after years of perfecting the two handed swirl and dropper method. The bottom illumination of the sample vial was an unexpected surprise and makes sampling after dark a snap. Small and compact too, well designed. :goodjob:
Reactions: borjis and PieterS
