Tested PH and the color isn't on the strip
theywanttoswim
3
The PH test came back as Red in color - do I add PH? The water is lime green, whiuch is a huge improvement from the swamp green it was yesterday.
Thanks!
JasonLion
Platinum Supporter
Welcome to TFP!
Can you tell us what brand/model of PH test you are using and what all of your other test numbers are?
PH tests tend to be unreliable at high FC levels, such as you might have when shocking the pool.
theywanttoswim
3
test results
Used a stip kit - can't see the name packaging is in bad shape
Total hardness over 1000
fFree chlorine: 0/0 - used 2 gallons of bleach already
PH Red in Color
Alakalinity 80
CYA 30-90
JasonLion
Platinum Supporter
Red normally means that the PH is very high. You can lower the PH with acid, either muriatic acid or dry acid (sometimes called PH Reducer or PH Down or Lo N Slo).
High PH can lead to calcium scaling, particularly when your hardness is very high as yours is.
Keep in mind that test strips are not very precise. When they are off the scale one way or the other there is obviously a problem. But you can't depend on them for exact readings. You should think about getting a high quality test kit.
Butterfly
10,045
South Carolina
Welcome to TFP!
My suggestion is to take a water sample to the pool store for testing and post the #'s back here. Then we could give better answers instead of guesses. :wink:
Also recommend the TF Test kit, link in my sig. It will allow you to take charge of your water. It is the best bang for your $ and it will save you time and money. Also, the seller, Dave, is a member of TFP and will be here to answer any questions you may have about the kit or testing issues.
When you post back, please include your pool and equipment info in your sig. It would also be helpful to see a pic of your pool water.
