Tear in new liner, small amount of rust visible
jason98
2
SC
Just had a new inground salt water 16x36 pool installed in November. Finally getting around to opening it up now that the weather is getting warmer. I noticed a small tear in the liner on the edge of one of the full end stairs. The tear even has a small amount of rust that is visible. If I run my hand over the edge of this pool stair I feel there's a small dent so I know it was an installation error, nothing I would have done, we haven't even swam in it yet. Pool installer is coming back out today to look. Since this is a brand new pool & liner what do you think is an acceptable resolution? Replace the entire liner with a new one? Remove the liner so they can mitigate the rust spot? Or simply patch it? Who should pay for all the water if the pool is drained and chemicals we've invested in?
Thanks for any suggestions and assistance!
ajw22
29,649
Northern NJ
Pentair Intellichlor IC-60
Welcome to TFP.
If the tear was not there when you closed the pool I don't know how you can hold the installer responsible for it. Tears is one of the risks you take on with a liner pool.
It is all a negotiation and anything the installer gives you is because he is a good guy.
I think the remediation is to lower the water to below the tear, put some rust neutralizer on the areas you can reach, and put a patch on the tear.
@jimmythegreek WWYD (What Would You do?)
Leebo
Admin
11,113
Eastern Ohio
jamjam
668
NY
i assume this is a liner over the steps? I wonder if you can patch the entire tread and riser (so there is no exposed edge to the patch)
jimmythegreek
In The Industry
Aug 10, 2017
3,900
Morris Cnty NJ
I cant really tell where it is in relation to steps. Regardless if it's less than a year old its warrantied if the PB is a standup company. We borrow water bags amd store the water on site for something like this unless theres city water available
Reactions: Leebo
