Taylor 2006 reagent refills
Winstonselect848
Active member
May 8, 2020
41
Tacoma/Washington
First time pool owner with a small AGP and a Taylor 2006 test kit. Will I get through the summer testing FC and PH daily? Just trying to get some insight on weather I should order some reagent. Also what other reagents I might run out of?
Thanks!
mknauss
34,632
Laughlin, NV
With the 0.75 oz amounts in the K2006, I would suggest you get a FAS-DPD refill at the least. Even a CYA one as it will last forever.
pH reagent does not last as well. I doubt you will need more of that.
TFTestkits.net has refills.
Winstonselect848
Active member
May 8, 2020
41
Tacoma/Washington
Thanks
I had already decided to go to TFtestkits.net to get needed refills and a few other items. So just the R0871 FAS DPD and the CYA. Thanks mknauss!
Reactions: markayash
