TA...
Thethreetheory77
65
Longwood, Florida
My TA is currently at 70. My ph is about 7.6. What is the the ideal TA for a manually chlorinated pool? Tfp says 60-90 but my test kit says 100-120. My daughter is complaining of her nose and eyes itching in the pool and she thinks it’s the chlorine level which is kept between 7 and 10. My cya is 60. I’m not sure which is the issue. The water looks great!
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,517
Leave you TA alone. It's perfect. Personally, I would let the FC stay between 5 and 7......you are wasting some chlorine but that has no affect on your daughter's itchy nose and eyes. When did you last test for CC's in your pool?
Thethreetheory77
65
Longwood, Florida
I tested cc last month. I can test again today. With it being so hot I am scared to set target at 7 because I am afraid if I lost 3-4 ppm I’ll be too low for my cya?
Thethreetheory77
65
Longwood, Florida
My target is 9 right now and it drops to 7 daily. Sometimes 6.5. I’m so nervous of an abrupt drop to below 5 so I’ve been keeping it higher just in case? Is that a bad idea🤷‍♀️
Thethreetheory77
65
Longwood, Florida
My target is 8.5 -9 right now too with a CYA of 60. Losing about 2-3 ppm per day unless its a bit cloudy out.
I don’t see how I’m waisting chlorine if I’m putting on fifty ounces a day exactly what I’m losing? I am just so afraid to dip too low as it’s hotter than heck in Florida right now- my pool feels like bath water!!!
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,517
The percentage of loss stays about the same so if you lose, for example, 35% of your chlorine each day, you lose more if you target 9 ppm as opposed to 7 ppm.
Look, if you feel safer, by all means put the FC in there. TFP is a teaching forum where we provide what we have learned and then you do what's best for you and your pool.
Another thought on that same subject.....Algae doesn't suddenly jump up and contaminate your pool because your FC got a little low overnight........It doesn't work like that (although many newbies believe it does). Algae is formed over some time by chronically inadequate chlorine maybe a couple of days in a row but certainly not overnight.
Thethreetheory77
65
Longwood, Florida
Ah ok. That makes sense. So with a cya of 60 my target should be 7? And what’s the lowest it should go? I just assumed it was a safer bed to over chlorinate lol. Today I lost 3 ppm. Water is incredibly warm and it’s SO hot. I added enough chlorine to bring it to 9. Tomorrow I’ll start dosing for 7 ppm.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,517
Check out the Chlorine/CYA article in Pool School......I think your minimum FC is 5.
3 ppm loss is pretty good in this Florida weather I think maybe it was 212 degrees today in Sebring 😳😳
Thethreetheory77
65
Longwood, Florida
It was hot as heck today! See, my worry is with targeting my fc at 7 what if I’m seeing a 4-5 ppm loss? That would bring me below the minimum. So then what? Make my target higher?
tillmac62
73
Gaffney, SC, United States
An option, though more work intensive, is to adjust your chlorine level to target more than once per day. Alternatively, you could set your target as your average or mid-point. For example, you experience a 4 ppm loss per day against a 7 target. Set your once per day target at 9. This gives you a daily FC range of 9 to 5.
zea3
12,874
Houston, Texas
Burning eyes might be a pH issue if you have no CCs. Some people's eyes are more sensitive, and dropping pH to 7.2 may help.
Thethreetheory77
65
Longwood, Florida
That’s what I’ve been doing is setting my target higher to accommodate for a fc loss of about 4 just in case. I can’t add chlorine multiple times a day as I’m not home to do so.
