TA 120 but everything else is good
Dba1047
Active member
Aug 10, 2019
41
Bayonne,NJ
FC 4
CC 0
Temp 82
Ph 7.5
CYA 55
Above ground heated 12x24
Last couple of weeks TA has gone from 70 to 120
All I have used is Home Depot liquid chlorine
It s crystal clear
Should I be concerned ?
thanks
Deb
Oly
1,618
Fresno, CA
No concern, simply watch your pH and keep it below 7.9 with muratic acid applied in front of a return jet. Test your fill water for TA. This is probably why your TA rises.
mknauss
32,529
Laughlin, NV
Only way TA could go up that much is by adding baking soda or sodium carbonate. Or a lot of fill water with high TA.
It is not a problem. Just maintain the pH in the 7's.
Dba1047
Active member
Aug 10, 2019
41
Bayonne,NJ
Thanks
I've had to add a couple of inches of water every other day between kids / evaporation / etc
Nothing but chlorine so far
