T-cell (T-15) not generating, but no errors
contraption
8
My Goldline Turbo Cell chlorine generator is not working. The salt display on the control box has been stuck at 2400 (even after adding 3 bags and checking that salt is at 3500 using a titration test kit) for weeks/months.
The Goldline control box has Power and Aqualink RS LEDs lit solid green, but it never shows "Generating". Also, none of my control panels (All Button, One Touch) show the salt level display any more either. The All Button used to show "Salt xxxx" when the filter pump was running, but not now. It appears that the system doesn't really know that the CLcell is attached.
I needed to clear my Jandy RS6 system memory a while back due to a Spalink problem. I'm guessing that the memory clear/reset wiped out some setting someplace for the CL generator.
When cycling through the display on the cell box I see these:
2400
86
33.2
0.00
OP
-0
r1.09
Anyone have any ideas?
Bruce
JasonLion
Platinum Supporter
37,880
The percentage setting appears to be set to zero percent. Have you tried turning up the output knob?
It won't display the salt level if the cell hasn't been active in some time. It can only measure salt when the cell is active.
contraption
8
Thanks. The output knob is disabled when the RS6 is hooked up - it is under full control of the Jandy.
However, that was a close guess. It looks like my Aquarite was set to 0% after the memory clear. Apparently when it is set to 0% the Salt display and 0% load is NOT displayed on the All Button, which seems a bit odd.
So, when I bumped up the cell load above 0%, everything went back the way I expected - the Generating light is on and the display is back.
All working here.
Bruce
