Switching from SWG to Chlorine ready to start up!
Syoung42
4
Las Vegas Nevada
  • The size of your pool in gallons: 13000
  • If your pool is an AG (above ground) or IG (in ground) In ground
  • If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass: Plaster/pebbletec
  • The type filter you have (sand, DE, cartridge): cartridge
  • If you know, tell us the make and model of your pump and filter.: Hayward
  • List other known details of the pump - Horsepower, Single speed, 2 Speed or Variable Speed :
  • List any other equipment you have: SWG, second pump, etc.
  • List what test kit you use to test your water: Ill either buy one here or Walmart or both
  • Please mention if you fill the pool from a well or are currently on water restrictions: will fill from hose
I need help getting started guys! My pool is empty(I had it cleaned) and this will be my first time going the chlorine route. Once the pool is full where do I start? What supplies should I go buy right now and which can I order and wait for?
mknauss
31,076
Laughlin, NV
Welcome to the forum!
Hate to ask, but why would you switch from a SWCG adding your chlorine each day to you having to dump in liquid chlorine each day??
First is to order a proper test kit. Only available on line. Either the Taylor K2006C or the TF100 from TFTestkits.net. Be sure to get a Speedstir.
You will need stabilizer, enough for 50 ppm CYA, muriatic acid, and liquid chlorine. Start with at least 10 gallons. You will be using at least a half gallon of 10% liquid chlorine EVERY DAY.
Please take all that information you posted and Create Your Signature - Further Reading
I suggest you read ABC's of Pool Water Chemistry.
Reactions: PointeTaken
PointeTaken
85
Hoover, AL
I’m curious why the switch to straight chlorine? Plenty of people go from chlorine to SWCG but I don’t know that I’ve encountered anyone doing the opposite except for when their cell or control bites the dust. If you’ve already invested in a SWCG and it works, it makes little fiscal sense to switch to $50+ worth of bleach per month (let alone the hassle). You may have a perfectly good reason, but we’re all about looking out for one another here so want to be sure you understand what you’re signing up for.
Syoung42
4
Las Vegas Nevada
Board is burned out and a costly repair. Salt cells every few years, I dont know
