Good Afternoon:
I have an extra pump that provides water for 2 deck jets and is pre-plumbed to add a slide in the future. However, on the suction side of the pump, the pool builder added a 3 way valve. I think they should've put a check-valve in this spot. Is it hard to swap out the "guts" of the valve and replace it with a check-valve"? Take a look at the attached picture and let me know if you see a reason for this type of valve in this spot. The pool equipment is elevated over the pool.
