- Jul 2, 2018
- 13
- Plaster
- CircuPool RJ-60 Plus
I am going to convert to a salt system and trying to figure a few things out before doing this myself. I currently run my pump at low speed 24/7 and kick it up very early am for about 4 hours using the Jep-r pump controller ( I have No other timers). I normally stop the pump for maintenance by the breaker switch not the controller. I understand that the swg should not run without the pump and not to rely on a swg low flow switch. Given my setup and routine, what do you feel is the beat way to wire this? Sure be nice if I could find a budget friendly controller that everything could be run thru.
