SWG readout doesn’t change when powered on
SPKNout4CHRIST
262
Goldsboro, NC
When I power on my SWG the voltage and other readouts do not change. Salt level reads as 0 although I have verified the salt level in my pool to be the optimal amount 3200.
I tried calibrating, but the number never started high and went down, just stayed at 0.
I haven’t taken the cell off to inspect it yet, but wonder if dirtiness would be the only issue since the numbers are changing at all. It shows generating for about a minute then says inspect cell and check minerals.
JamesW
18,419
How old is the cell and box?
Make sure that the plug is in good condition. Unplug it and reinstall the plug.
Move the switch to off, then back to auto and go right to instant salinity to see what it does. Then, do that again.
SPKNout4CHRIST
262
Goldsboro, NC
The cell is around 3 years old. I replaced the motherboard in the box about 4 years ago.
Plug looks good and was seated well.
Will try that next. I’m about to pull it and see how the cells look.
SPKNout4CHRIST
262
Goldsboro, NC
I think I found the issue. When I removed the cell I could see some discoloration where the cable enters the cell. I removed the plate and found this mess. Looks like it is time to get a new one. :rolleyes:
108910
