SWG Question
Shoogle
Active member
Jun 30, 2018
25
OKC/Oklahoma
Finding 10% liquid chlorine This year has been the worst, so I’m inches away from pulling the trigger on a SWG. I’ve been considering it for two years, but being unable to find the liquid chlorine this year has been the tipping point. I’m considering the CircuPool RJ-60 (originally considering RJ-45, but they’re offering a “upgrade for $10 more” special).
I have a question on how/when the SWG knows to run? I typically run my single speed pump for about 10 hours overnight. I was also considering the SJ-55, but it was mentioned that a separate timer would need to be connected.
I’m hoping someone can simplify how the SWG knows to run if my pump is only running overnight?
I appreciate the help!
mknauss
43,982
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Do you have your current pump set up on a timer? If so, you would wire the SWCG to that timer too. If you have a VS pump, you need a timer for the SWCG so you can schedule it to only get power when the pump is running.
Reactions: Shoogle
Shoogle
Active member
Jun 30, 2018
25
OKC/Oklahoma
Yes, current pump is on a timer...I guess it’s a standard timer? Its a rectangle box, with a circular center with metal on/off clips that rotates.
So either (RJ or SJ) would just be connected to the same timer for the pump and runs only when the pump does?
mknauss
43,982
Laughlin, NV
Fiberglass
Correct. The RJ allows for more fine adjustment of chlorine generation.
Brett S
724
Orlando
Keep in mind that you can upgrade from the RJ-30+ to the RJ-45+ for $10 as well, so the effective price of the RJ-45+ is $1039 and the effective price of the RJ-60+ is $1229. The RJ-45+ will be more than enough for your pool. Upgrading to the RJ-60+ is fine if you want to do that, but realize that it’s actually $190 more, not $10 more.
Reactions: Shoogle
Shoogle
Active member
Jun 30, 2018
25
OKC/Oklahoma
Thank you for your help!
So now knowing that either can be set up to power through the existing timer, the decision (outside of initial cost/warranty/replacement cell cost) is SJ-55 ($849) with the standard percentage outputs 25/50/75/100/SC, or the RJ-60 ($1229) for better control.
Decisions, decisions!
Thank you!
Shoogle
Active member
Jun 30, 2018
25
OKC/Oklahoma
Thank you!
