SWG Pentair IC40 warranty question..
Bvacchiano
397
Sugar Land, Texas
Let’s say my pool equipment was installed Jan 2018. I had a flow switch give out and was fixed Jan 2020 obviously within the 3 yr Pentair Warranty. If the flow switch failed again in July 2021 would that be covered under warranty . I realize it’s past the initial 3 years but that same part that was fixed a year ago failed? Basically does new parts installed as part of a warranty get an ADDITIONAL 3 years to them for warranty??
mknauss
51,248
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Technically, no. But I would still give Pentair a call and plead your case!
If they will not cover, there are some methods to use a separate temperature probe to bypass the one in the flow switch.
