SWG panel showed "check salt" light green, Check cell blinking red. Now normal.
Went out this morning to do maintenance and panel is reading normal again. We had a slight cold snap overnight night before. Could it be that water got too cold and when it warmed up a bit, I just happened to check on it just after SWG had begun to be able to generate again and it hadn't quite finished coming back online at the panel? We did nothing to it, panel just went back to normal readings on it's own.
FC = 8
CC = 0
CYA = 70
Ph = 7.6
TA 80
Salt is a bit low at 2890 so will be bumping it up to 3200 today. Just curious as to why it might do that. Pool temp is 57 right now and it's due to warm up. I know TFP says umder 60 degrees is too cold, mfg says 50. Seems to be somewhere in between in actual practice. Through testing, it appears that it continues to generate at less than mid 50s. Pool is clear just trying not to miss anything.
Thanks.
FC = 8
CC = 0
CYA = 70
Ph = 7.6
TA 80
Thanks.
