This year after 8 seasons, my Aquacal Autopilot SWG cell finally gave out.
I had it replaced by the original installer, and they also said a board in the controller needed replaced, which I was originally a bit skeptical of but the entire job was still less than 7 years of chlorine.
It worked well for several weeks after the replacement, but all of a sudden the system is not detecting salt, and thus not generating chlorine.
However, the Taylor salt test shows a salt level to 3400 PPM, which is well within the operating range. I tried going through the maintenance menu and calibrating the salt level to 3400ppm, but the system is still showing 0ppm.
I have a call in with the installer, but was wondering if anyone here has seen similar.
