Hey Everyone,
This is our 2nd year with our in-ground vinyl pool (bought the house last year), and TFP helped me a TON last year! This year I was off to a good start again, however, it seems like our SWG is not producing the same amount of chlorine as it did last year with the same settings. Last year I was able to run the pool pump for about 4 hours a day with SWG set to around 40-50% and it had no issues producing enough. This year I have had to run the pump 6 hours a day with SWG set to 80% and it still doesn't seem like it is keeping up.
About a week ago we did have a very slightly cloudy pool when FC dropped below minimum for about a day before I realized something was up with SWG. I quickly brought it up to about half SLAM level and it cleared right up. My initial thought was that maybe even though I thought I had killed all the algae that there might be some residual Algae using up the FC as fast as the SWG could use it, so I did a OCLT last night, but it passed. I'm not sure what to do at this point. I know Salt Cells are about a 5 year life span, and this one looks kind of old, but there is no serial number on it for me to figure out the year of MFG. we currently are a turbocell 9, which is rated for 25k pools (We have about 18,000), and I saw somewhere on here that you guys recommend a cell that is 2x or more for your pool size, so do I need to upgrade to a turbocell 15? Any help with troubleshooting or recommendations would be awesome.
OCLT:
Saturday Evening 6/20/20
FC = 8
CC = 0.5 (Did a bunch of swimming during the day)
Sunday Morning 6/21/20
FC = 8
CC = <0.5
Full test results Sunday Morning 6/21/20
FC = 8
CC = <0.5
pH = 7.5
CH = 125
ALY = 70
Cya = 70 - 80 (Always have a hard time judging on this test, but it's definitely at least 70)
Salt = 2800 (I know this is a little low at the moment, but it is above the minimum for my SWG, I will add some today. Also this low amount of FC problem was still an issue when Salt was at 3200+)
OCLT:
FC = 8
FC = 8
CC = <0.5
FC = 8
CC = <0.5
pH = 7.5
CH = 125
ALY = 70
