Swamp green pool....help!!!!
laweatherred
140
Levelland Texas
My pool is swamp green...we have tried ever thing the pool store has told us to do...still unchanged over about a 3-4 week period....HELP...any suggestions?? Thanks!!
laweatherred
140
Levelland Texas
ok, sorry just read the reccomendations for posting...my test results are bad simply because I have let it go for a couple of days out of frustration and lack of money...my pH is over 8.2 and chlorine is maybe a 1....I have had it perfect though during the process and that was tested by pool store...I have a 24 round AG pool...we even changed our sand in our filter a week ago but still no results on clearing it.
frustratedpoolmom
In The Industry
May 20, 2007
12,177
SWSuburban Chicago, IL
Have you read Pool School?
Start with:
ABC's of Pool Water Chemistry
then
Defeating Algae
and
Turning Your Green Swamp Back into a Sparkling Oasis
Don't forget:
Shocking Your Pool
Finally you'll need a good test kit so you don't have to go to the pool store anymore (if you don't want to):
Test Kit Comparison
I know its a lot of information to take in all at once, but we are here to help. So read the links I gave you, a couple of times, and then give us some test results, and we'll help walk you thru.
Post your pool specs/equipment info into your signature: Go to User Control Panel, then Profile, then Edit Signature.
We can help you thru this! :)
laweatherred
140
Levelland Texas
Thank you....I will tackle it again this weekend....one more question though...even though my FC level is in shock range...how often should I continue to add more liquid chlorine? Do I wait for it to come down some or not??
laweatherred
140
Levelland Texas
Thank you, JasonLion!!.....also I don't really know the exact specs on my pool, we have had it about 7 years..I will try to get that info. and attach it to my profile...not exactly sure how to do this though...
laweatherred
140
Levelland Texas
ok, so I have poured the liquid chlorine to it today and brushed the entire pool....I have backwashed twice...My question is if the pressure gage is not increasing how often would I still need to backwash to get the green to filter out???
JasonLion
Platinum Supporter
37,880
I would backwash at least every other day as long as the pool is very murky with algae. When the water starts clearing up you want to clean the filter less often, since a slightly dirty filter is better at catching very fine debris.
laweatherred
140
Levelland Texas
If I have been using bleach and keeping it at shock level and my CYA still seems to be low, can I put a Trichlor puck in my skimmer to help keep the FC up and help raise the CYA and lower the pH. Readings just now using strip test (because that is all I have right now) were as follows:
FC: 10-12
pH: 7.6-7.8
TA: 180
Cya: 20 (or less)
We did determine we had used too much sand in our filter and have removed some. Hoping that this increases the filter effectiveness.
Any advice will be appreciated.
Also, how do you start a new forum??
JasonLion
Platinum Supporter
37,880
I suspect that you mean to say topic, rather than forum. The current topic is "Swamp green pool....help!!!!". To start a new topic, you pick a category on the main index http://www.troublefreepool.com/index.html, for example this topic is in Swimming Pool Start-up and Closing. Click on the section name, which will take you to a list of topics currently in that section. Near the top left corner, but below the headings will be a "+ New Topic" button. Press that, enter your questions and press Submit.
laweatherred
140
Levelland Texas
Thank you!!!
Other Threads of Interest
