Sunstone Quartz plaster fail
I will tell you that does not look that bad. I have seen far worse where you could even see foot prints :(
The darker the plaster the harder it is to get it perfect. It is all in the skills of the installers.
If you really do not like it you can push your PB to do an acid wash. That might even it out some BUT know it will lower the life span of your plaster by a couple/few years as it removes some of the plaster.
I agree with Kim after seeing many hundreds of examples of all pebble and quartz finishes here.
Could it have looked better with better application protocol? Quite possibly.
But the cure may be worse than the disease.
