Sun screen vs. pool filter
bmoreswim
Platinum Supporter
4,273
Central MD
#2
USE SUNSCREEN!!! One thing you can do to lower the amount making its way to the cartridges is to throw Scumbugs in the skimmers. They soak up surface oils. Then squeeze them out daily or as you empty the skimmers. There are several other varieties as well. One is like a ball.
The scumbugs can also be used to clean the black gunk off of the inside of the skimmer (oils).
https://www.amazon.com/Scumbug-Oil-Absorbing-Sponge-Quantity/dp/B00SYXDGPG
