- Jun 8, 2020
- 590
- Plaster
- Pentair Intellichlor IC-40
My PB included a single actuator with an EasyTouch P4, and it was for controlling the waterfall feature on/off. During the build, I upgraded the controller to a EasyTouch PS4-SCG, and this kit includes two actuators. So I now have 3 actuators to use in the setup. The electric crew wired them up, and but didn't install them on any of the valves.
So looking at the layout, I'm wondering how I should ask for them to be set, to give me some useful functions.
My thought right now is to have them install an actuator on
What I'm not sure about is how to set the stops and configure the ET for control though.
Should the waterfall valve stops (actuator 1) be set to 100% returns (so the waterfall can be turned off), and the other stop set to the 50% mark for equal flow to both?
Then the return/pressure cleaner port cut-off valve (actuator 3) can be set to 100% open, and 100% closed, so I can operate the waterfall without the returns if I want to?
Will the ET allow "scene" configuration, where for example, I can have a scene called "Slow Solo Waterfall" which would set actuator 1 to the 50% mark, actuator 3 to 100% closed, and the VSF pump to say 600 RPM? So only the waterfall receives return water at a slow rate...
For the skimmer vs floor drain suction, I was thinking to set the stops to 20% on both sides.
This would allow me to operate it one of two modes, right?
I appreciate any input, or even just confirmation my approach is a good one
- The 2-way return valve, to control waterfall vs. the other returns
- The 2-way suction valve, to control skimmers vs floor drain
- The return/pressure cleaner port cut-off valve
- 80% skimmers, 20% drain
- 20% skimmers 80 % drain
