Suction side leak / air getting in system
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
Hi all
I am pretty sure my pool recently developed a suction side leak or potentially skimmer issues/air getting in to skimmer
VSP running 2100 RPM (9 PSI with clean filter) - the pump lids starts off with a few bubbles, and within a 3-4 hours those bubbles have increased in size
no actual bubbles coming from the returns, but a very faint sound, if underwater, of air.
With RPM on 1800, significantly more bubbles and what sounds like air in the top of the filter, almost like a crackling sound.
What is also interesting is that is doesn't seem to be constant, there was a few days last week where i was certain no air was entering the system. I also increased the water level above the skimmer and everything was fine(but could have just been a coincidence). Water level currently at or above halfway of the skimmer, maybe 60% above.
I have a 3 way jandy valve and can post pics/videos of whatever.
I can post pictures; have someone coming out 6/14 but $325 just for the testing alone is pretty steep and i would like to figure this out if possible. I have used them in the past for underground suction side leak.
I tried the hose trick and had the same issues. I have not changed the drained plugs yet.
Please help!
cowboycasey
8,590
Southern OK
CircuPool SJ-40
try taking the O ring out of the lid and clean it with dawn dish soap.. then lube it really good and install it back then tighten the lid back.. the air should stop :)
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
Hey I bought a new o ring, lubed it up. I did not clean inside where the o ring is placed
i will clean it well and report back
Orion7319
547
Rock Hill, South Carolina
Hayward Aqua Rite (T-15)
Have you checked your skimmers weir door to make sure it’s working properly? If it doesn’t the skimmer can suck in air.
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
Weir door in place and functional. I have messed around with the door and air still in system. Ugh. The skimmer does kind of create a vortex but I can’t get rid of it even if I lower the RPM and mess with the jandy valve
maybe i should purchase a new one?
cowboycasey
8,590
Southern OK
CircuPool SJ-40
if there is a vortex in the skimmer that is where your air is coming from.. fill your pool more to get rid of the vortex... do you have only 1 skimmer or do you have a main drain or 2 skimmers?
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
1 skimmer and 1 main drain, but main drain is blocked off. I have a suction side cleaner, jandy valve is set for 50 percent suction and 50 percent skimmer
Filling up pool more as i type this.
cowboycasey
8,590
Southern OK
CircuPool SJ-40
most of my air I get in the pump is from my suction side hose connections.. they let air in... but you can move the valve to the suction cleaner side like 60% or 70% to stop the vortex in the skimmer...
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
ok i will try that too...2 years ago i had an underground suction side leak ( damaged PVC pipe from a pine tree) that was replaced
If I turn off all pressure to the skimmer, there are quite a bit of bubbles in the pump lid.
So possibility I need new hose connections? What if I disconnect the hose in order to diagnosis it?
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
if I fill the pool too full, then the skimmer doesn't work very well.
I am trying it again, last time i had it full ( too full as covered the skimmer), I didn't get any leak but of course the skimmer did not function.
cowboycasey
8,590
Southern OK
CircuPool SJ-40
You is a double edge sword.. too full and the skimmer does not work and not enough and it sucks air... I bought new hoses for the suction side cleaner and only used the ones needed to stop the air...
bryanqueen602
Active member
Jun 15, 2018
31
phoenix AZ
i am going to disconnect the hose from the suction port in the pool and see if that helps with the air getting in to the skimmer.
how do i tell which hoses need replaced?!
cowboycasey
8,590
Southern OK
CircuPool SJ-40
if you move them around in the water you will hear the air coming into the hose... at least I did with mine... They will have little slits in the hoses...
