So after ruling out some incorrect guesses, I now think I have a suction side air leak that is only noticeable when vacuuming.
Ever since we installed our new pump, the pump basket partially fills with air the second the vacuum hose is plugged in. At first I thought the problem was the hose because we accidentally bought and 1.25 in. diameter hose instead of a 1.5 in. diameter hose. I incorrectly assumed that since this pump is slightly stronger than our old once (1hp vs 3/4hp) that it just couldn't pull enough water through the smaller diameter hose on high speed. We recently bought a 1.5 in. diameter hose and there is no difference. It then occurred to me that there are people with much stronger pumps that are able to vacuum without issue so hose diameter is unrelated to my problem. Logically, if my basket not filling with water is not cause by a lack of water, then air must be getting pulled in from somewhere.
So far I've tried tightening the lid, which resulted in about 50% less air in the basket. I then removed the lid and added some extra pool lube to the seal. There was no real difference, but I only added the lube to the visible side of the o-ring.
- My next step is gong to be adding more lube to both sides of the pump lid o-ring.
- If that doesn't solve it I think the next step should be doing the same thing to the o-ring at the front of the pump
