Sucking Jets
Rudy24
1
Kansas
Hello,
I have had jets sucking water in my hot tub for quite awhile in different areas; two seats and one of two foot jets. I recently drained and refilled and used the hose to force water into those jets while filling. Those jets now work, but now other jets are sucking water. The jets are not adjustable, they are just a tube. The pump works, the jets that do work, work with water and blowing air bubbles. Any ideas?
Thanks!
Rudy
Newdude
2,562
NY
Check this one out.
I had similar problems. If it was just a couple of jets i would try a shop vac on the dead ones to try and get the air out of those lines.
mas985
13,252
Pleasanton, CA
It is more than likely a blocked air line for the jet. Remove all jets (not just the exterior fittings) and run the pump to purge the lines.
