Subpanel - fuse or circuit breaker?
Enumjon
100
Tijeras, NM
Hi all, a nitpicky electrical question for someone smarter than I am. My current electrical setup has power coming off my house main panel to a subpanel that powers all the pool equipment. That subpanel is 20+ years old, and has fuses. Is there any benefit to switching it over to a modern circuit breaker panel?
I am not having any issues with the panel currently. However, I do hope to upgrade my pump soon to something more this century, which means that surge protection will become more of an issue. Thanks-
JamesW
25,720
I would suggest an automation system that includes a subpanel.
The pump should be variable speed.
The pump should receive power from a gfci breaker.
Add a surge protector for the pump.
I would suggest the Intellicenter and Intelliflo pump.
Enumjon
100
Tijeras, NM
Thank you for the quick and concise reply. Gives me more to research.:)
Reactions: JamesW
PoolGate
6,141
Damascus, MD
Jandy Aquapure 1400
If it has fuses, it is more than 20 years old, more like 50.
  • Haha
Reactions: panic_button
Enumjon
100
Tijeras, NM
The house was built in 96, so it can't be too old.
Unless they scavenged some parts. That may explain a few things...
Enumjon
100
Tijeras, NM
I do know that some people - such as my father - like the fuse box option. He is an engineer of the belt and suspenders type. He likes that with the fuse panel you can pull the fuses, and then you KNOW that circuit will not be accidentally turned on. He had fuses put on the panel that went to his new AC unit. I asked him about the surge protection capability vs. circuit breakers, and he did not know.
