Stumped with my algae situation
John Rock
91
Montreal, Quebec
How are you chlorinating and when was the last time you checked your CYA?
I'm using liquid chlorine (12%) and checked CYA this morning with the rest. I haven't tried to use CYA this year (wanted to test if chlorine would be more potent without it) but used maybe 10 pucks during summer, so I have a bit in the pool.
JJ_Tex
2,299
Prosper, TX (DFW)
Pentair Intellichlor IC-40
Ok, good on the liquid chlorine. We sometimes see people using trichlor powdered shock that dont realize they are adding CYA in the process.
If we call your CYA of 30, I would say get your FC to 12 and keep it there to knock out the algae. Try not to let it drift down to 8-9, which will include testing/adding 3-4 times a day.
Seems like you keeping your FC elevated, so it is a bit frustrating to see that the algae is coming back quickly. Do you have any pictures?
John Rock
91
Montreal, Quebec
I tried taking a few pictures, but it's not really visible in the pictures. It always shows up in the same areas: at the base of the vertical wall on one side of the pool, and near the stairs on the shallow end. It will go away if I start the pool cleaner again.
