I just installed a Circupool Edge 40 for my above ground pool. I have had an algae problem since opening the pool a month ago (Located in Texas). I have initially added 600 lbs of pool salt and all was well. I had very high Chlorine on the Boost setting. But didn't kill my algae problem. Now some weeks later, still fighting the algae problem and have very low chlorine. I have tested the salt level and it showed it was low (about 1000 ppm). So I added another 600 lbs of salt. I expected that to boost the chlorine but now I have the same issue. Very low chlorine and low salt again. My pool specs are: 26000 gal (30' round), sand filter, above ground. Circupool Edge is about 3 weeks old/installed. Chemicals show: Ph is a little high right now, I am adding acid to lower that. Stabilizer seems to show Ok levels and alkalinity seems to be about right.
Some things I have tried along the way: 2 different algaecides which caused very high copper levels, should be down after using a flocculant that removes metals. Next tried PR-10000 to remove any phosphates and hope for killing the algae with just chlorine.
No dice. The circupool shows no red lights for any issues, all seems fine. I have put the pump on low and tried to watch for bubbles. I think I see some moving past the window on the cell.
I am at a loss and could sure benefit from some suggestions. Appreciate any thoughts anyone might have with this situation.
